Hello!
I have developed a Lotus Notes add-on in vb6 that uses the lotus notes com object. I have a client that is not able to run the add-on. Upon looking at her system, she uses a command line ‘=’ to locate the notes.ini file. If I just run notes it appears that the id file has not been registered.
How can I get the com objects to follow what the notes client does with the equal sign?
I appreciate your help.
Thanks,
Justin
