"Activities has encountered a problem"
every few minutes I get the following error message box.
Problem Occurred
X ‘Activities’ has encountered a problem.
an internal error occurred during “activities”
                OK    Details
I can’t stop it ! driving me crazier
Subject: Fwd’d to development
Activities/DH
Subject: Accounts would have been deleted
Add accounts to the contacts from your colleagues that may help it
Subject: We need some more info …
We need some more info to be able to help. This is not a common error, so something seems wrong.
what Connections version do you have ?
was Activities working before?
did you upgrade your Notes client recently?
do you have TAM or Siteminder in place?
can you add a screenshot of the error message, also logs,
zip the logs under …<notesdata>\workspace\logs
We should be able ot help once we get more info.
Thanks.
Subject: more lack of activities
This error message started when I first updated to 8.5.1 client. I am having serious problems signing on to the client now. see my other post about not responding when first logging in. I was able to fool the notes logon last Friday by using NLNotes and selecting other on the first logon screen then selecting my notes ID file. When I did this the activities error was no longer there. More later today when I find a way to logon to notes again today. It crashes with a security problem on my notes data so I am doing an Acronis restore to my backup file.
I was able to do an Acronis restore of my entire Notes directory ane get Notes back. To sign-on, I had to select my ID file under other to get Notes pointing to the correct user. It appears that the 8.5.1 migration does not properly handle the ID file migration.
