ACT! for Notes problem
I know ACT! is not supported anymore, but we are upgrading to the latest version of AFN, 4.2 (for Notes 7). When a user attempts to open the Calendar, they get:
“$EXECUTE+3: Class or type name not found: CALENDARVIEWBROKER”
After clicking ‘OK’ the Calendar opens.
Attempting to open the ‘ToDo’ results in:
“Cannot find external name: UIEVENTOBJECT” which appears twice. After clicking ‘OK’ twice, ToDo opens.
I’m sure these are references to script that isn’t there. I found the following in the Globals of the ($Calendar) view:
Sub Initialize
Dim s As New notessession
If s.Notesbuildversion Then
	Execute(|
				Use "CSUIViewClass"
				set cvCalendarViewBroker = new CalendarViewBroker
I’ve checked the “CSUIViewCLass” library which references another library which references another library…
As the Calendar and ToDo open and are functioning normally, I really just need to eliminate the error dialog boxes.
Thanks in advance.
Subject: ACT! for Notes problem (ADD’L INFO)
Through the forum, I’ve tried some fixes:
  1. Deleted the Script Libraries and copied them back in from the template.
  2. Replaced (rather than Refresh) design.
  3. Made Local Replica, replaced that design, then replicated back to Server copy.
Unfortunately, all to no avail.
