Access Control Problems with Database
I am having difficulty setting appropriate permissions for a database that I have created. In the database, there are folders and documents. Access has been limited to a group of users. However, each user is only allowed to access one specific folder. Is there any way to set permissions within the database?
Subject: Access Control Problems with Database
You can look at folder or view properties and click on the access tab to determine who can access the view or you can use a frameset with outline entries that can be hidden from certain users, groups or roles.
Well, you can put security access on views and folders …
…but take great care here. That only stops a user from looking at that folder or view - it does NOT prevent them from looking at documents that might be in that folder or view - big difference.
The Notes Security model implements security at the Document level using Reader fields, and I suspect that is what you are really trying to do here - limit who can read documents.
The reason that securing the views will not protect documents is that all users (on the Notes client) can create their own private views.
