I’m just starting out with embeding controls into notes forms (so pointing me to any documentation would be nice).
I’m having a problem setting and retrieving values from a control. When I have lotus script debuging on, it works fine. But if I don’t have debuging turned on, I can’t access the properties.
Here’s a simple form that recreates the problem (this is not the control I’m using, but it should be one that everyone has):
Create a new form
Create a new object
Select Control and then choose Microsoft Rich Textbox Control
Change the name of the control to ole1
Change (RunReadOnly) to True
Change the Text property to “TEST”
In the form’s Postopen put the following code
Sub Postopen(Source As Notesuidocument)
Dim ole1 As Variant
Set ole1 = source.GetObject("ole1")
Msgbox ole1.Text
Turn on lotusscript debuging
Preview the document (you should see a msgbox with “TEST” in it)
Turn off lotusscript debuging
Preview the document (you should see a blank msgbox)
