Hello,A long time ago, we configured a reverse proxy with Apache to access several mail servers from the Internet.
Since a recent upgrade of the primary server, when we try to access databases with the mail85.ntf template, it fails.
If we revert the template to dwa7.ntf or inotes6.ntf on the same server, it works…
Does anyone configure successfully a reverse proxy access with mail85.ntf templates ?
Regards
Subject: PMR opened today
Subject: Provide more details
Subject: What exactly is the problem?
can you provide some more details, pls?
And yes, I am (successfully ) running a reverse proxy in the described way
Update: Take a look at this technote http://www-01.ibm.com/support/docview.wss?uid=swg21412267
Subject: More details
Hello and thanks for your responses.Here are more details :
Domino 8.5.1 FP2 server (primary) running on W2K3
Domino 6.5.6 FP2 servers (secondary) running on different OS
SLES with Apache 2.0.55 configured as a reverse proxy, rewrite engine activated
I configured SSO and the HTTP task of Domino, the default page opens a Domino Web Access redirect database (iwaredir.ntf) configured as MAILSERVER.
Here is a sample of the httpd.conf
RewriteEngine on
RewriteLog /apache2/logs/webmailacme-rewrite_log
RewriteLogLevel 9
# -- Generique pour acceder au dossier inotes (commun aux serveurs)
RewriteRule ^/iNotes/Forms(.*)$ http://sles10.acme.lan/iNotes/Forms$1 [P]
RewriteRule /iwaredir.nsf(.*)$ http://sles10.acme.lan/iwaredir.nsf$1 [P]
RewriteRule /names.nsf(.*)$ http://sles10.acme.lan/names.nsf$1 [P]
RewriteRule ^/((icons|domjava)/.*)$ http://sles10.acme.lan/$1 [P]
RewriteRule ^/favicon.ico(.*) http://sles10.acme.lan/favicon.ico [P]
# -- sles10
RewriteCond %{HTTP_REFERER} ^(.*)sles10(.*)
RewriteRule ^(.*)sles10(.*) http://sles10.acme.lan/$2 [P]
ProxyPass /sles10/ http://sles10.acme.lan/
ProxyPassReverse /sles10/ http://sles10.acme.lan/
# -- Chemin retour par defaut
ProxyPassReverse / http:/sles10.acme.lan/
The problem is with databases with the mail85.ntf template applied.
If I convert the databases back to inotes6.ntf, the webmail is fine.
I think something has changed with the template but I don’t know what.
Thank you for you help.
Regards
Subject: Webmail redirect not working
Even I am facing the same problem. Any solution yet ?
Regards
