7.0.2 FP1 message and system timedate problem
I thought I share this with people and see if others have same problems. Ever since upgraded to server 7.0.2 FP1 and client 7.0.2 I notice mysterious timedate problems but I can not reproduce it.
  1. Domino Web Access (DWA) always tells me that my time zone is wrong and I need to fix it. But, it’s not wrong.
  2. Few of my client PCs timedate all of sudden change to something else. I had to manually change the timedate back. If it was just one PC did this then I would not consider the possibility of Notes, however, there were few PCs that did this.
  3. My server system datetime was changed and I had to reset it and restart the server.
  4. Some of my messages datetime go out of whack. One even says 2/24/2007 at 2:04 AM, that’s tomorrow!
Maybe this is not entirely 7.0.2 related? But, I observe this only after upgrading.
Subject: 7.0.2 FP1 message and system timedate problem
Have you followed all of the documentation from IBM on how to fix everything. Did you update all of the DWA cab, jar, and dll files per the IBM documentation? Your server’s date and time should not have changed yet - that will happen on 3/11/07. Have your PCs been updated as well?
Subject: RE: 7.0.2 FP1 message and system timedate problem
That’s a broad question. I probably have not “followed all of the documentation from IBM”. I just did stright upgrade and refresh mail files to DWA’s R7 template. On the client it’s a straight upgrade.
For DWA-specific issues you’ll want to see Technote 1241063.
