65 second Load and then fonts tiny, until Notes restart
First Notes launch takes 65 seconds to get to the log in dialogue. Then when in fonts are tiny.
Exit Notes, and there are no process running (ps -ef | grep notes).
Start Notes… 5 seconds and fonts are fine.
Tried using the default Luxi fonts, same thing.
Ubuntu 8.04 64-bit.
Subject: Hardware Specs
Just to point out that the specs of my laptop are pretty good, so there should not be such a performance issue :
Ubuntu 8.0.4.1 64-bit
HP Compaq 8510w
Core2Duo T7700 (2x 2.4 GHz)
4GB RAM
nVidia Quadro 570M (v173.14.09)
HTS72201 7200 RPM SATA2
I have to use 64-bit because of nice but chunky IBM software in VMs for work and study.
Subject: Just tried 32-bit VM
Just tried it in a 32-bit 8.0.4.1 VM on the same hardware and is really fast.
I am using Ubuntu 8.0.4.1 Desktop 64-bit because of the IBM software that I have running in VMs, and there is no way that I can drop down to 32-bit, due to memory limitations.
Regards
Mark
Subject: RE: 65 second Load and then fonts tiny, until Notes restart
Resolved in Beta 2
