I cannot seem to clear this error below. Any direction would be helpful.
Iris Hotfix Installer FI1.01 for W32Intel
Copyright (c) Iris Associates, Inc., 1994-1999. All rights reserved.
Executable created 13:44:23 Jan 20 2004 for (null).
Upgrade started at 12:47:13 Feb 26 2004 in D:.
DLGSTATE_DIRS: Before Freeing the memory for giPartitions = 1
DLGSTATE_DIRS: Before Freeing the memory from = C:\LOTUS\DOMINO\DATA
DLGSTATE_DIRS: Before Freeing the memory from gpNotesData
Using Notes program directory C:\LOTUS\DOMINO
Using Notes data directory C:\LOTUS\DOMINO\DATA
C:\LOTUS\DOMINO\nstrings.dll
Identified Release 6.5.
The file js32.dll is missing or in use by another process. Skipping
I have seen this couple times before. I never found out why this happened. To get around it, I uninstalled the client the reinstalled the newer full version, not the incrimental. Not the answer but maybe a temporary solution to try.
I’ve seen this go both ways, so either one of these might help:
Reboot the computer.
Make sure js32.dll is in your path
If 2 doesn’t work, remove it from your path, move all instances of js32.dll to another directory not in the path, reboot and try again.
Often times it’s another application using it, like the performance monitor that may be running as a background task. Shut this down, reboot and try (yet) again.
