Has anyone else had problems with their Help documents since installing 6.5.1? Help worked fine before, but now if I type in anything it spits up all kinds of unrelated stuff. For example, just to test it for you now, I’ve typed in ‘agent’ and it’s popped up 52 fairly useless docs, the first of which is entitled: ‘TeamRoom Team Member Profile’ and that does not contain ANY occurences of the word ‘agent’. And as another test, I’ve typed in ‘TeamRoom Team Member Profile’ to see if it spits out the same doc at the top, but it hasn’t. What is it searching for all of a sudden? Do I need to re-install 6.5.1, or is this a fault that someone’s noticed?
Thanks in advance for any enlightenment…
