Hi
I’m navigating a view for all available categories in it through an agent, to generate an Excel report. In Local it works fine as expected but on server some times it works fine and sometimes it fails to navigate to the next category after navigating the first category and raises the error message “4005 entry not found in index(viewname)”
Please help me!!!
Regards
Khader
Subject: 4005 entry not found in index
check for sorting once and what is the lookup synatx usingif that particular item is not available also entry not found index will comm
to remove this write failsilent in every lookup
s
Subject: RE: 4005 entry not found in index
I think my query has been misunderstood totally. Please check the query that I have posted earlier. Below is the code that I’m using.
Sub AllFunctionsReport
On Error Goto PrintErr
Set nav =thisview.CreateViewNav
Set entrya=nav.GetFirst
Dim object As NotesEmbeddedObject
Dim xlApp As Variant
Dim oWorkbook As Variant
Set xlApp = CreateObject("Excel.Application")
xlApp.Visible = True 'set to visible, this can be moved to the end if you wish
Set oworkbook = xlApp.Workbooks 'handle to Workbook
oworkbook.Add
'giving the header names in excel
xlApp.cells(1,1) = "EmployeeName"
xlApp.cells(1,2) = "EmployeeCode"
xlApp.cells(1,3) = "FunctionName"
xlApp.cells(1,4) = "SubFunction"
xlApp.cells(1,5) = "ReportingManager"
xlApp.cells(1,6) = "WeekNo"
xlApp.cells(1,7) = "CreatedDate"
’ xlApp.cells(1,7) = “ToDate”
xlApp.cells(1,8) = "Category"
xlApp.cells(1,9) = "Activity"
xlApp.cells(1,10) = "ProjectCode"
xlApp.cells(1,11) = "ProjectName"
xlApp.cells(1,12) = "FromTime"
xlApp.cells(1,13) = "ToTime"
xlApp.cells(1,14) = "WorkingHrs"
xlApp.cells(1,15) = "Status"
xlApp.cells(1,16) = "Remarks"
'this highlights the headings
xlApp.application.Rows("1:1").Select
With xlApp.application.Selection.Font
.bold = True
.ColorIndex = 00
.Name = "Arial"
.Size = 10
End With
'this autofits the columns
xlApp.cells.select
xlApp.selection.Columns.AutoFit
xlApp.application.rows("1:1").Select
i = 2'start from second row
While Not entrya Is Nothing
If entrya.IsCategory Then
If entrya.ColumnValues(0)<>"" Then
Set entryb=nav.GetChild(entrya)
While Not entryb Is Nothing
Set thisDoc=entryb.Document
If Not thisDoc Is Nothing Then
fdate=doc.FromDate(0)
tdate=doc.ToDate(0)
For dat=fdate To tdate
firsttime=0
cnt=Cint(thisDoc.SetNoInt(0))
cnt=cnt+1
For j=1 To cnt
str1=thisDoc.GetItemValue("Date_"&j)(0)
If str1<>"" Then
If Cstr(str1)=Cstr(dat) Then
EmployeeName$=thisDoc.Name(0)
EmployeeCode$ = thisDoc.EmpCode(0)
FunctionName$ = thisDoc.Function(0)
SubFunction$ = thisDoc.SubFunction(0)
Dim nam As New NotesName(thisDoc.ReportingTo(0))
ReportingManager$=nam.Common
WeekNo$ = Cstr(thisDoc.weekN(0))
CreatedDate$=Cstr(thisDoc.GetItemValue("Date_"&j)(0))
Category$ = thisDoc.GetItemValue("Cat_"&j)(0)
Activity$ = thisDoc.GetItemValue("ActivityDesc_"&j)(0)
ProjectCode$ = Cstr(thisDoc.GetItemValue("ProjectNo_"&j)(0))
ProjectName$=thisDoc.GetItemValue("ProjectName_"&j)(0)
FromTime$ =Cstr(thisDoc.GetItemValue("Frmtime_"&j)(0))
ToTime$ = Cstr(thisDoc.GetItemValue("Totime_"&j)(0))
WorkingHrs$ = Cstr(thisDoc.GetItemValue("Timediff_"&j)(0))
Status$ = thisDoc.Status(0)
Remarks$ = thisDoc.GetItemValue("ActRemarks_"&j)(0)
'___ put values to the row
xlApp.Range ( "A" & Cstr ( i ) ).Value = EmployeeName$
xlApp.Range ( "B" & Cstr ( i ) ).Value = EmployeeCode$
xlApp.Range ( "C" & Cstr ( i ) ).Value = FunctionName$
xlApp.Range ( "D" & Cstr ( i ) ).Value = SubFunction$
xlApp.Range ( "E" & Cstr ( i ) ).Value = ReportingManager$
xlApp.Range ( "F" & Cstr ( i ) ).Value = WeekNo$
xlApp.Range ( "G" & Cstr ( i ) ).Value = CreatedDate$
' xlApp.Range ( "G" & Cstr ( i ) ).Value = ToDate$
xlApp.Range ( "H" & Cstr ( i ) ).Value = Category$
xlApp.Range ( "I" & Cstr ( i ) ).Value = Activity$
xlApp.Range ( "J" & Cstr ( i ) ).Value = ProjectCode$
xlApp.Range ( "K" & Cstr ( i ) ).Value = ProjectName$
xlApp.Range ( "L" & Cstr ( i ) ).Value = FromTime$
xlApp.Range ( "M" & Cstr ( i ) ).Value = ToTime$
xlApp.Range ( "N" & Cstr ( i ) ).Value = WorkingHrs$
xlApp.Range ( "O" & Cstr ( i ) ).Value = Status$
xlApp.Range ( "P" & Cstr ( i ) ).Value = Remarks$
i = i + 1
Next
Next
Set entryb=nav.GetNextSibling(entryb)
Set thisDoc=Nothing
Wend
Set entrya=nav.GetNextCategory(entrya)
Wend
Exit Sub
PrintErr:
Msgbox "Code - " & Str(Err) & ": " & Error$ + ". (onLine " & Str(Erl) & ").",,"Error"
Exit Sub
if you are using caregory views for exporting you will get error so to avoid this you create on hidden you with same view how you are using just remove the category and export and check for duplication values also\after exporting toexcel sheet you filter theexcel sheet then everything will come in categorised way
