32-bit code to 64-bit?
Hi, everybody,
We use 32-bit Domino and are going to upgrade the servers to 64-bit Domino 9. We have an app that was designed in C++ and run as a task on the Domino server. It is a 32-bit app and it does not run on the 64-bit environment. Does any one know any tools that could recompile it to a 64-bit app?
Any comments or suggestions will be appreciated. Thanks.
Lisa
Subject: Options
Subject: Re: 32-bit code to 64-bit?
Check out the presentation below. I used it while researching an upgrade deployment from Win Server 2003 32-bit to Win Server 2012 R2 x64 boxes that also would involve transitioning to Domino 9.
BP 102: IBM Domino 64bit - All You Need to Know
http://www.nashcom.de/nsh/web.nsf/ff5ce882e73ab026c1256942003bdf10/6084a81e9f2c2b00c1256cc30030c6c1/$FILE/bp102.pdf http://www.nashcom.de/nsh/web.nsf/ff5ce882e73ab026c1256942003bdf10/6084a81e9f2c2b00c1256cc30030c6c1/$FILE/bp102.pdf
We too had some 32-bit tasks running on Domino that I could find no way to port (not ours; a vendors…). Ultimately, the above convinced me that, currently, the 64-bit OS provides the majority of the benefit, even when running 32-bit Domino. Note the quote on page 10 of the presentation: “Running 32Bit Domino on 64bit OS gives you already most of the performance and scalability benefits.”
I’ve not been disappointed. The 30+ Domino EXEs now have up to 4GB each to expand into instead of sharing that 4GB on the Win 2003 server (I can’t believe we were actually surviving before on a 4GB server…).
The Domino processes typically consume 8-12 GB RAM (out of 32GB) with no one process running beyond 0.8-0.9GB. Traveler, ScanMail for Domino from Trend Micro, and HTTP are typically top memory consumers, followed by nserver and several nupdate tasks. We have a couple of 8-10GB databases with > 1-mil docs each and dozens of views, which probably accounts for the nupdate tasks being so high on the memory usage, at about 0.67GB each.
I will probably transition to 64-bit Domino at some point in the future, but 32-bit Domino on 64-bit OS has, so far, provided the performance boost and headroom needed right now while giving time to figure out how to either deal with 32-bit compatibility issues or find a replacement for what they do.
Subject: 32 bit ot 64 bit
For a domino server the requirement is to install the 64 bit code, and then move your Notes applications to the server. If you have a specific coed which is in 32 bit, and you have tested and it will not operate in a 64 bit environment, you will nee to recompile the code using a 64 bit compiler
Subject: 64-bit is our global standard
Thanks, Mark, for the comment. 64-bit Domino is the global standard that we have to follow even though quite a few existing 32-bit tools could not run well on it.
Subject: compiling issue
The 32-bit code does not work in the 64-bit domino server environment. We tried to recompile the code via Visual Studio and received quite a few errors, e.g. No platform specified; Cannot open include file: ‘global.h’: No such file or directory; etc. Any advise on how to resolve these issues? Thanks.
