2nd Post: Problem with Richtext control and IE 6 crashing
Hi again,
is there anyone, who has a solution for that (MS IE)bug?
When I use the rich text option for web access “using best fit for OS”, the IE shows an (I think) active X control, which could be a fine tool for editing in the browser.
The iNotes template uses the same as far as I can see.
BUT: As soon as I try to insert or edit a table in that RTfield (with one of the table buttons), the IE 6.0 crashes.
With IE 5.5 it works fine.
(If you want to test it, you can do it in the showcase section of IBM: https://showcase2.notes.net/inreg.nsf/regform
there you can create your own iNotes web mail access).
Thanks A LOT for ANY IDEA!!!
Uwe
