2nd Post - Journaling - rollover file location
In the server’s Configuration Document under the Journailing tab we selected ‘Copy to local database’ in the Method field and put this path and file name ‘companyname_journaling\mailjrn.nsf’ into the Database Name field.
The Mailjrn.nsf is being created under the path above but the periodic rollover files are being create in the root directory.
Why are the rollover files being created in the root? Do the rollover files have to be created in the root? My client wants to keep his root directory ‘clean’ and wants an easy way to backup and purge the rollover files.
Help!
